Ask Your question...
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100
Threads
- CM870 EGR Woes (2 Replies)
- Cm870 low boost high egt (28 Replies)
- Oil coming out of turbo down pipe joint (2 Replies)
- Slop when I let off the pedal (9 Replies)
- Paccar Endurant problems (1 Reply)
- metafiles (1 Reply)
- Odd engine sound (1 Reply)
- questions about a Cummins ISM turbo (8 Replies)
- Future of trucking (17 Replies)
- Insite help (0 Replies)
- Fixing a bad tune? (2 Replies)
- Engine brake undefined (2 Replies)
- Using insite to check over heat history (2 Replies)
- issues with nexiq connecting to insite (6 Replies)
- CM 870 exhaust manifold slip joints seals (6 Replies)
- 12.7 60 series DDEC3 hard start (5 Replies)
- Exhaust manifold bolt holes stripped (8 Replies)
- ISX15 to x15 2012 Pete (3 Replies)
- Coolant leak inbetween head and block. (14 Replies)
- New truck (4 Replies)
- Batteries cooking (5 Replies)
- egr cooler blockoff (3 Replies)
- ISX15 oil pump pickup tube screen — is the newer tube upgraded, or just re-tack the s (1 Reply)
- X15E3 CM2350 Cruise Control fault (8 Replies)
- Fuel pump failure (4 Replies)
