01-30-2017,
ok so i have cured the problem. If you are having the same issue you have two choices. first one is to replace all the wiring from the plug located under the truck near the fire wall back. or you can go to a electrical supply store and pick up a can of electrical contact/circuit breaker cleaner and spray the contacts this will clear your problem right up.
