(12-25-2019 )dumptruckisx Wrote: [ -> ]After reading all 10 pages of this thread i just have a questions. I have a CM2350 and am wondering if anything is different during the install process. I can still tap into the #5 port on the passenger side or is this different for the CM2350?
should be the same as mentioned above.
Is port #5 pre-filter oil or already filtered oil?
Essentially these ISX blocks haven't changed in years, I would say you are fine.
(12-30-2019 )DDlighttruck Wrote: [ -> ]Is port #5 pre-filter oil or already filtered oil?
if your referring to this post...
http://rawze.com/forums/showthread.php?t...873#pid873
then port#5 is the place to connect the bypass filter. - it is pre-primary oil filter and should not drop the overall oil pressure of the truck.
(01-01-2020 )Rawze Wrote: [ -> ] (12-30-2019 )DDlighttruck Wrote: [ -> ]Is port #5 pre-filter oil or already filtered oil?
Yep, that’s the pic I’m referring to
Why wouldn’t you want to use a port that’s after the primary oil filter?
I’m slowly gathering the pieces to build a bypass filter, I’m just reading up on what others have done
(01-01-2020 )DDlighttruck Wrote: [ -> ] (01-01-2020 )Rawze Wrote: [ -> ] (12-30-2019 )DDlighttruck Wrote: [ -> ]Is port #5 pre-filter oil or already filtered oil?
because your pulling oil away from an already restricted circuit.
(01-03-2020 )arch_stanton Wrote: [ -> ]I just installed one on 2018 KW
you mounted it a bit differently from what i have seen most people make their own J bolts. A close up of what you did there would be nice. how hard was it to get mounted? it looks nice and clean good job by the way!
