Full Version: ISX and Bypass Oil Filter Systems
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Installed The Amsoil bypass on mine last wk ,used j bolts and 1/4 aluminum plate cut to Order from Metal mart, warren ,mi
Got it almost a100% as in the tube video that this guy in Chicago
First bypass I installed I drilled the frame, was the one Kevin R makes money on and it was a 3x as expensive...on a truck prior to this one
Google ISX15 Amsoil bypass filtration,if anybody want an idea how to do it
For the hose kit u may want to find a custom hose maker shop in ur area or ask Amsoil to sell u their but you'll still need the end connections to the engine
On my 2350 the oil cooler doesn't have as many places were to hook the oil supply as the on in the foto, I do have 2-3 and 5 ((used it))
https://www.amsoil.com/shop/by-product/f...e=BMK21-EA
What is the difference between this and the 350$ unit?
(06-21-2016 )jorden486 Wrote: [ -> ]https://www.amsoil.com/shop/by-product/f...e=BMK21-EA
The eaBP-120 filter is designed for long haul trucks. Dont forget if you sign up for Amsoil Preferred Customer program $10/6 months you get 25% off.
Thanks Vinny baga dounts!
By signing up for the Preferred customer program you save about $70 on your first order,$$$ then buy a replacement filter and save some more coin.
I got a new lead on custom hoses today from a local farmer that buys allot of hydraulic lines and recommends them without condition.
http://hoseshopinc.com/
You can never save too much!
Tell'em Rawze.com sent Ya!
[attachment=1687]
Installed! 2009 Kenworth T2000, ISX CM871
(07-12-2016 )jelshant Wrote: [ -> ]Installed! 2009 Kenworth T2000, ISX CM871
That looks nice! Good job! What did you use for a bracket to mount the filter?
Looks good
(07-12-2016 )jelshant Wrote: [ -> ]Installed! 2009 Kenworth T2000, ISX CM871/ i used a stainless steel 1/4 inche that was laying around at my father's. We ended up welding a piece of angled iron to connect the s/steel plate to the original metal bracket that holds the washer fluid tank. I'll get another pic and post it soon.
Reference URL's
