(12-01-2016 )Rawze Wrote: [ -> ]Just make sure you have all the same model injectors. There are 2 different types depending in your I HP and CPL settings. Mixing them or putting the wrong ones in is not good for the engine.
Question regarding your info boss.
Working on a cm2350 after doing the upgraded valve seal job, I noticed on insite the ecm does not have any recognition of the cpl # of each injector per cyl #
Every other truck ive hooked up to with insite is spot on.
All this info on this injector replacement page/inj # on insite was completely blank...
Ive never seen this before, especially on the cm2250 motors.
Is this something that was supppse to get programmed into the ecm from factory??? Or what? Ive checked and rechecked yup its blank.. obviously each number on inj/cyl needs to be entered into insite im guessing
Do the cm2350s, not need this info??? Im thinking yes, yes they dor
Never had issues with this motor running different only in the winter.
(12-01-2016 )joed2323 Wrote: [ -> ] (12-01-2016 )Rawze Wrote: [ -> ]Just make sure you have all the same model injectors. There are 2 different types depending in your I HP and CPL settings. Mixing them or putting the wrong ones in is not good for the engine.
YES, the CM2250/CM2350 ECM needs the injector trim codes! -- It will effect how efficient the engine runs.
