12-11-2016,
Pages: 1 2
12-11-2016,
(12-11-2016 )Texasdude74 Wrote: [ -> ](12-10-2016 )scottydogtruck Wrote: [ -> ]2903rpm....is your motor still running? should be in pieces at that rpm...
Detroits will handle a lot of rpm. The entire reciprocating assembly is very light weight and the stroke is relatively short. My friend Herb is a S60 loon and has a hot rodded Detroit and pulls hills at 32-3300rpm. Some place in CA did the ecm with mapping to 3600rpm. It won't be far behind my Cat up a mountain but will be turning more than twice the rpm. His is not a reliable setup, hydro locked once and had a runaway turbo on the 301 in FL. Been torn apart 3 times in last two years.
I know of a guy in Nebraska that makes reliable 725hp DDEC 4 12.7 series 60 engines. And 2350 torque. He has guys drive them in his trucks. All OE parts.
12-11-2016,
(12-11-2016 )Jarhead79 Wrote: [ -> ](12-11-2016 )Texasdude74 Wrote: [ -> ](12-10-2016 )scottydogtruck Wrote: [ -> ]2903rpm....is your motor still running? should be in pieces at that rpm...
How high is he spinning them?
I don't believe any 12+ liter Diesel engine will last long if it regularly sees 2k rpm. 3k rpm is on borrowed time.
Unilevers
12-12-2016,
we did a ddec v 14l in a race truck that spun 2750 and was north of 850 to the wheels. i say north of 850 because it was a single axle that we couldnt stop from spinning on the dyno rollers.
it was bone stock except for turbo and injectors, and has been throttled in racing for over a year now and is still running great. It never sees normal RPM's its held to the floor pretty much all the time its running.
12-12-2016,
(12-11-2016 )Texasdude74 Wrote: [ -> ](12-11-2016 )Jarhead79 Wrote: [ -> ](12-11-2016 )Texasdude74 Wrote: [ -> ](12-10-2016 )scottydogtruck Wrote: [ -> ]2903rpm....is your motor still running? should be in pieces at that rpm...
I'm not sure high high rpm but fought it's 3000 rpm that sounds like a sled pull engine being used in a working truck. I wish I had your buddys money. Or tell me where to apply.
Pages: 1 2
