Full Version: This true about isx heads?
Had a mechanic tell me that if you take the head off your isx and it has half a million miles or more that you have to inframe it or you'll never get the head torqued down properly and you'll have problems. Any truth to this??
Some "mechanics" crack me up.
ROFLMAO. Run. Run fast and far.
Although it is advisable to replace one if it's off around that mileage on a emission motor. But it's not due to the inability to get it to fit correctly again. It's just a wear item.
I know a guy in Virginia that was told by a Peterbilt mechanic that if an ISX reaches a million they aren't able to be inframed, only replaced.
(07-18-2017 )Texasdude74 Wrote: [ -> ]I know a guy in Virginia that was told by a Peterbilt mechanic that if an ISX reaches a million they aren't able to be inframed, only replaced.
Better not tell Rawze that. He'd bust a gut laughing.
Depends how you look at it. Some are saying this mechanic is horrible, but maybe he's a guy who doesn't like to half ass his work.
At that many miles, if you were to inframe.. .. there is a good possibility you would want to cut the deck as it would be uneven or warped. Well if you would need to cut the deck, it would make sense that the head gasket may not seal 100% if you just take the head off. Yes you can change the head gasket and re install the head.... but it won't be 100%
Not saying I suggest such things but could be his train of thought.
I'm with Brock on this. I would replace the head with a new one if this is an EGR/DPF/SCR motor. How many stories on here have we read about these heads? Mine made it to around 600,000 when it started to fail. I nursed it another 100,000+ miles before it needed babysitting, then a year of feeding it coolant, then it eventually failed. A new head would have been cheap when all of the lost revenue and coolant was figured in.
And look at Cummins, they are using new heads and selling them as remans as the stock they get back as cores are junk. Honestly, if my motor was over that 500,000 mile mark and the head needed to be removed, I would replace it with a new one if I could swing it. These are not the motors I grew up with to say the least.
(07-18-2017 )tree98 Wrote: [ -> ]Had a mechanic tell me that if you take the head off your isx and it has half a million miles or more that you have to inframe it or you'll never get the head torqued down properly and you'll have problems. Any truth to this??
It sounds like that mechanic possibly had some bad experiences, or worked with someone else who did.
<-- Not giving him excuses but some other informations or poor training may have gotten twisted into what your mechanic believes. Here is some infos related to this...
* It is an unspoken rule that for any reason, if the head has to come off an ISX after the 450,000 mile mark, then the head itself should not be re-used. It is considered a discard item and costs about as much as a turbocharger. The bearings and valve seats in the head typically wear out about 2x faster than the bottom end does. The overall engine life is extended greatly if the head is replaced after this mileage on it and it has to come off anyways. My own engine was a good example of this when I inframed it at 950k miles. I could have put on a head and likely ran another 800k+ on the bottom end components. It was only the head (one injector cup that had seepage for a very long time and bearings) that were worn down.
This is the more likely reason though ...
* The main reason why any head would have to be removed on an ISX is for a failed head gasket. It is uncommon to remove the head for any other reason except maybe head itself had a failure like a spun bearing in it, etc.
It is almost always a bad head gasket that leads to its removal. Just about every single shop out there checks liner height once it comes off and thinks they are ok. They then put on a new gasket and/or even a head and the engine fails again a second time a few months later. It is NOT because they can't seat it or torque it properly, but something more sinister that gets missed.
Liner fretting is the most common reason for the initial failure and subsequent repeated failures on the head gasket to an ISX. The problem is that the procedure in the book, and when they get trained, is not thorough enough for them to correctly diagnose it. In fact, out of every single head gasket failure I have ever seen on an ISX, EVERY SINGLE TIME that the head gasket failed was because of liner fretting.
It would be EXTREMELY RARE for a head gasket to fail on one and it NOT be a liner issue aside from human error (under-torquing the bolts, damaging the gasket during install, etc). On many of the ISX head gasket failures I have seen, it was difficult to spot the underlying cause of liner fretting but it was always there and could be detected. Sometimes you have to look beyond a simple height check. In fact, a height check is not really a reliable way of detecting this at all if you ask me. A big problem is poor training in this area. A simply check of liner height is all the book/training says you need to do and is not reliable in itself for detecting liner fretting/issues. -- IT IS AN INCOMPLETE METHOD AND SHOULD NEVER BE RELIED ON IN ITSELF!!!.
Long before the head comes off though,.. pressurizing the coolant system overnight with the oil pan off will usually show the area/what cylinder caused the failure. Crushed/flattened fire rings are another sign of liner fretting too. The only way a fire ring (part of the head gasket) can get crushed/flattened is if the liner gave way and dropped down at some point under stress, causing the fire ring to flatten abnormally in the same area.
Because of this incomplete training and methods, the liner fretting gets missed way too often and the result is that it costs the truck owner tens of thousands of dollars in repeat work when their engine fails again a few months later. This is because the underlying problem got overlooked. Here is a bit more on detecting liner fretting with pictures...
http://rawze.com/forums/showthread.php?t...48#pid7648
Now put yourself in the shoes of the mechanic who does no know this and only has training via checking liner height and nothing more. His shop replaces a few head gaskets because they have failed, and the engines all do it again in a short time. He scratches his head and comes to that screwed up conclusion that you have mentioned there and tells all his friends. -- The spread of mis-information starts and becomes the norm after a while. Sad indeed when there are actual reasons and solutions to those problems out there to prevent the guy who has to foot the bill yet again when his engine fails a second time.
At the end of all this, there are some things to always keep in mind here. They are...
* After 450k miles, if the head comes of for any reason whatsoever, it is highly recommended to simply replace it instead of re-working it or even worse, simply putting it back on. This is due to the fact that it wears 2x faster than the bottom and overall engine life will be extended greatly if you do so.
* Unless someone took the engine apart and made some kind of mistake, if the head comes off because of a gasket failure, even if you had a bad delete or excess power levels set, you are guaranteed that there will be a liner fretting issue somewhere to go along with it. It can be found, but you sometimes have to look very hard to see it. In this case, this leads to the conclusion that YES, if you have any kind of head gasket failure, you are almost guaranteed that pulling the liners and counter-boring the block will follow. -- I.E. the bottom end being taken apart and an inframe before it is over with. Certainly though, it is NOT because of some voodoo alignment or torquing issues because some mechanic just simply does not understand or has poor training and has jumped to some conclusions.
Always keep that in mind and by the way,.. I am full of s%$it too.
Mis-information is everywhere in this industry. Is it more common to find than good information. Sometimes that mis-information even comes from the engine makers and OEM shops themselves. They are NOT the "word of god" so to speak and are just as infallible as anyone else. Problem is that the bulk of mechanics that get OEM/certified training have their head squarely stuck in the sand. They only generally get just enough training that the maker wants them to have so that it maximizes profit and minimizes effort. It is all done under the pretense of conformity and standardization but it is really nothing more than a mask of righteousness for them to hide behind in the end.
Reference URL's
