07-24-2017,
07-24-2017,
What are you having difficulty with? The actual sensor itself? If so cut the wires off and use the box end of a wrench, not sure if you can find a deep enough socket??
What kind of truck is this?
07-24-2017,
(07-24-2017 )jimeneztrans84 Wrote: [ -> ]Any tips or tricks to remove rear nox sensors? Thanks
The sensor comes with the little electronic box it plugs into. You have to remove both together.
07-24-2017,
Having difficult wrenching it out. Tried spraying wd40 a couple of times. It's on there good. I'm scared to cut the wires and not be able to take it off.
07-24-2017,
I don't have one on my truck but whenever I do an O2 sensor I spay wd40 hit it with a chisel on the outer side and heat it up with a propane torch and just work it
07-24-2017,
(07-24-2017 )Rawze Wrote: [ -> ](07-24-2017 )jimeneztrans84 Wrote: [ -> ]Any tips or tricks to remove rear nox sensors? Thanks
Make sure you DON'T cut the wires from the sensor!!! Cummins is now charging for a core for the sensor....If you cut the wires to get at the sensor using a deepwell socket..your core is KAPUT!!!
