08-06-2017,
(08-06-2017 )Billdozer2 Wrote: [ -> ]It will only hurt your wallet. The sensors were $502.46 a piece
Holy cow!
(08-06-2017 )Waterloo Wrote: [ -> ]Cheaper to rid yourself of the mandate... ;-)
(08-06-2017 )zyNoT Wrote: [ -> ](08-06-2017 )Waterloo Wrote: [ -> ]Cheaper to rid yourself of the mandate... ;-)
Agreed and sadly that is usually the best path to take. On the CM2250 the delete usually consists of unplugging all sensors. I can tell you if you go through NJ it's anywhere from a $500-$8,000 fine if you fail their NOx test during a random inspection. You won't fail if you have a tune that keeps everything looking "stock" and all sensors are still plugged in. It's a red flag if they're missing or unplugged. As far as I know the CM2250 cannot be deleted properly without sensors being unplugged as emissions managers kick back in if they see an emissions-related sensor or part. Correct me if I'm wrong.
I will say this, the CM2250 operates usually pretty well if all sensors are functioning properly, you should only be seeing a regen once every 3-4 days if you drive 3,000-4,000 miles a week. I've seen IMAP sensors cause problems, animals stuck in the exhaust pipe, backpressure sensors, NOx sensors in and out, bad EGR valves, bad EGR coolers, bad after treatment injectors, SCR fluid buildup, etc.
