02-20-2016,
For eliminating the Coolant Radiator/Transmission Oil Cooler combo that is prone to leaking radiator fluid into the transmission and destroying it.
http://www.roadranger.com/ecm/groups/pub...0b-as2.pdf
Page 19 shows a external cooler bypass that eliminates the hoses
Part http://www.drivetrainamerica.com/k2402-f...ort-cover/
Oil Cooler Recommended –
With engines 350 H.P. and above.
Required
–With engines 400 H.P. and above and GCW’s over 90,000 lbs. [40,823 kgs.]
–With engines 400 H.P. and above and 1400 lb ft. [1898 Nm] or greater torque.
–With engines 450 H.P. and above.
–With engines 1500 lb ft. [2034 Nm] and above.
Excluded
–With Fuller Advantage Series transmissions.
Page 28 shows Eatons Oil Cooler and an Optional Oil Filter
Required
Excluded
