Installed a Pro Ride this afternoon. Easy to do after watching everyone else. Used two floor jacks with 4x4s to support the rear corners of the cab. Installed the top plate first, then loose bolted everything else together (to avoid alignment issue on the strut). Took about 4.5hrs. The shocks were totally shot. The cab had slammed down hard enough to buckle the back wall of the cab and crack the outer skin. Used a porta power to shove everything back as much as possible. Will finish with a little welding. Also replaced the front cab bushings. [attachment=3384][attachment=3386][attachment=3387]
Anybody using ProRide notice a lot of body roll compared to stock option?? I installed mine like a year ago and feel like the body rolls more... then again I can't remember if it rolled with stock. But in comparison with my mid roof Cascadia, the Prostar rocks like a boat.
(03-14-2018 )CFR__AND_SONS Wrote: [ -> ]Anybody using ProRide notice a lot of body roll compared to stock option?? I installed mine like a year ago and feel like the body rolls more... then again I can't remember if it rolled with stock. But in comparison with my mid roof Cascadia, the Prostar rocks like a boat.
Never paid much attention to it myself. I was just sick of the over-priced components from the dealer so I figured I would try it out. So far I am quite happy with the results.
My honest opinion they should've used the Volvo airbags like on the 780/860 sleepers. They are much bigger and would support more weight than those dinky Peterbilt bags..
(12-29-2017 )DosGatos Wrote: [ -> ]Installed a Pro Ride this afternoon. Easy to do after watching everyone else. Used two floor jacks with 4x4s to support the rear corners of the cab. Installed the top plate first, then loose bolted everything else together (to avoid alignment issue on the strut). Took about 4.5hrs. The shocks were totally shot. The cab had slammed down hard enough to buckle the back wall of the cab and crack the outer skin. Used a porta power to shove everything back as much as possible. Will finish with a little welding. Also replaced the front cab bushings.
I shi#t bricks just thinking about hooking up a welder around my truck. Any tips that could help me face that fear :)
