Full Version: Oil change time for new to me truck
I'm going to doing my first oil change since buying this truck (13 w900 with ISX de-leted).
I've read on here that the engine likes high zinc oil so I was going to use Rotella T4 and was thinking about adding some of this for an extra bump:
https://www.amsoil.com/shop/by-product/m...e=BRKQT-EA
Good idea or no?
Thanks
(12-18-2017 )Skman Wrote: [ -> ]I'm going to doing my first oil change since buying this truck (13 w900 with ISX de-leted).
Good idea or no?
Thanks
http://rawze.com/forums/showthread.php?tid=1913
You may find this posting enlightening. Read it and decide for yourself, but there seems to be no discernible downside to this approach. I went with Sta-Lube because NAPA can get it, and they're close to me.
As a side note- If you have any sort of oil leaking from the head, you will smell gear oil from time to time!
Good idea or no?
Thanks
Not sure I would trust a "break-in" oil so much and it is also difficult to get zinc additives that do not contain ceramics.
here is an old post on just this discussion...
http://rawze.com/forums/showthread.php?t...831#pid831
Reference URL's
