[attachment=3357]After doing a forced regen only 400 mi. ago. I get the DPF light on the dash coming on. So I start a forced regen using insite.pic attached. Does anyone see a problem with data. Took pic 15 min into regen.
Thanks in advance.
then the inlet temp is definately too high. It should only peak about 600 degrees or so even when the dpf is at 1100 degrees. Here is comparison video...
You may have to pull the DPF and DOC and have them blown out/cleaned from ash buildup then flow tested. After that, do a "dpf replacement" procedure in insite.
You may also have a leaky doser injector causing high inlet temps too.
Pull the Doser pipe away from the back of the turbo and crank the engine. Look to see if the Doser is leaking fuel or coolant.
Might not be an issue with yours but a friend of mine accidentally hit the rocker switch and disabled his regen. Kept having to stop to do forced regens till he noticed it was turned off on his switch panel. Lol
