(04-08-2016 )Jerzy609 Wrote: [ -> ]I need some help with this Insite. I ordered Insite 7.62 off of eBay and it arrived at my house about 10 days before I got home. I remember that I was supposed to send my pc-id back to the seller but I haven't been contacted back and eBay says the sellers store is closed because of difficulties. Idk know if I should just try to send it back and try to get reimbursed either thru the seller or eBay or if somebody can help me out with this.
Thanks Curt
I had the same the issue until I bought insite fix software. If u can give me your picd I'll help you. Just sent me an pm.
(04-12-2016 )jesse20 Wrote: [ -> ] (04-12-2016 )snailexpress Wrote: [ -> ]Ebay
does anyone have the new 8.1 version of insite? on the inside page it appears i can just download it but how much would the license cost me?:s
$600
Lady told me it was $436, or close to it for the fleet version. Supposed to do everything but load calibrations.
I got my inline 6 all installed, just need the {**Content removed by protection bot**- filesharing.}. Can some one PM me options that may exist?
Hi everyone! Which one inline 5 or 6 you would recommend to buy and use for CM871 2009 with software insite 7.6.2. Or your suggestions. Thanks!
Either of those will be fine if you just plan on using Insite. If you plan on using software for OEM modules, ABS, gearboxes, etc then consider a Nexiq adapter.
Can someone possibly help me out with the insite software as well? I have a 2012 cascadia with a cm2250, thank you in advance
What exactly do you need help with?
