I use a CPAP machine so I need to purchase a good pure sinewave inverter. Anyone have a model that they recommend?
Considering it is for a medical device, the top of the line of all brands is Xantrex Pure sine wave inverters.
I don't think mine Xantrex is pure sine but definitely is the best brand I ever own.It is originally installed in my Volvo and I am running a lot of stuff on it.Highly recommending this brand.
Fridge, 900 watt small micro, laptop and cpap what size? Is 1500 watt inverter good?
(02-07-2018 )Blake Wrote: [ -> ]Fridge, 900 watt small micro, laptop and cpap what size? Is 1500 watt inverter good?
As long as it isn’t all on at the same time.
I had a 1,000 watt before, it worked fine for a microwave, but would not start a fridge. Anything with a motor needs about 10 times it’s running wattage to start. 1,500 may be enough. I had an 1,800 that worked fine for a fridge.
I currently have a 2,500 watt pure sine wave and that’s seems to run everything.
Just be sure to use large cables for the power. I use welding cable.
I am running this one for about 6 months now...
https://amzn.to/2Ln466c
Pure sinewave, works good, and handles everything thrown at it so far. It can be bit touchy and will shut down easily if something causes a slight power surge though. I had a power strip that was intermittent causing it to shut down randomly, but once I replaced that strip, it is working good now.
2 years after your post, How is that inverter working for you Rawze?
