Full Version: Injector heip
I pulled injectors #1&2 due to not passing leak test. The top have 4088725 on them the tips have 4088662.
According to Quickserve my cpl calls for 4088665.
Needing some direction, I know cat injectors have different spray pattern. Not to knowledgeable about Cummins.
What is your engine serial number?
(01-31-2018 )Rawze Wrote: [ -> ]What is your engine serial number?
79227495 cpl 8520
Found out I was looking in the wrong place, the metal piece that holds the spring had the part #
They are 4088665's
Still learning, Thanks for all the help!
Reference URL's
