(11-28-2017 )Oil Slick Wrote: [ -> ]I’m new and sure glad I read all this info because I would sure hate to F up my ISX 15.
BUT I do have an idea. When I clean the intake manifold what about putting a blind we’re the EGR pipe meets the intake manifold? Simply cut a thin piece of metal to the shape of the gasket. This will completely block the hot EGR air hopefully giving better performance from not having hot gasses entering the intake.
It might plug the filter faster since the soot is not going back into the engine.
Whatcha think Rawze?
Thank you for posting videos of cleaning the pipes and sensors. Mike
Most truck owners start out with those same thoughts. If it were that simple everyone would have done this already a long time ago.
I have seen people come up with the "what if i just block it off" - and the "what if I use a resistor to replace the sensor" and all sorts of other plans that simply don't work very well.
- Bad idea Because ...
* it is illegal in usa/canada.
* The ECM (engine computer) will see a restriction and try to overcome it, and you end up with improper turbocharger and/or engine combustion control that significantly shortens the life of something.
* The engine will derate because it knows something is wrong and eventually cause a shutdown, putting you on the side of the road.
* The regen system for the DPF wil no longer work correctly
* The engine will no longer have the ability to control and regulate exhaust temps and the engine will run lean, risking the cylinders and the pistons unless some re-programming of the combustion cycle occurs.
* What you describe is referred to as a "block Plate" or "blocking plate". Unless it is made of 304 stainless or some other 1/8" thick or thicker material, anything "thin" as you call it will be eaten through in a short time or corrode at a rapid rate by the corona in the hot egr gas, all the moisture buildup in the now dead circuit, and all the other effects that it suffers. - I have seen guys use Galvanized plates... they corrode through after a while. - I have seen guys use aluminum plates ... The corona in the egr gas eats them up and you get holes in them after a while. - I have seen guys use steel,.. They get eaten through and chunks of rust end up in the intake valve seats, I have seen guys use other materials like cheap stainless and/or zinc coated from home depot,.. most will not hold up for more than a few months. there are only 2 things I have seen hold up properly long term at that particular joint you are referring to in the intake. - 304-stainless, or really thick (1/8" or thicker") plates made from copper. -- Not only that, but there can be up to as much as 90psi (yes ninety pounds per square inch) of surge pressure on the back side of that plate when the engine is under heavy boost control.
There are a lot of reasons that make it a bad idea all on its own without some ECM re-programming even if you live in a country that allows such mods.. These engines are NOT simple and dumb. They are vastly complex and the programming in the computer is designed to fight against all kinds of attacks like jumped out sensors, blocking devices, and all sorts of other things the typical redneck can come up with. The EPA requires the engine makers do this too. Earlier engines like the CM870 were somewhat forgiving, the 871 not so much, and the newer CM2250 and CM2350 are smart as hell against this type of tampering. The ECM not only checks to see if a sensor is inside its operating range, but it checks to see if its feedback is moving in accordance to the engines operations too. The ECM also uses several sensors in combination to monitor systems that it normally would not be able to as well. Throw one of them off and several things are sometimes effected in bad ways. -- There is no "fooling it" in a sens of the word for very long at all without ending up with problems somewhere. Although some guys are in self-denial over it, even when the egr on the older CM870's is defeated without proper re-programming/methods, etc. end up with a turbo derate (only 32 lbs boost or so) that creates excess EGT's and shortens the life of the turbocharger by about 1/3.
-- I.E. > I would not recommend such things on their own at all. It takes someone who is really good with the ecm and the engine both for that kind of stuff to happen properly without problems down the road. Installing block plates and/or defeating sensors on the engine always requires some form of re-programming in the ECM to get correct. Because of this, it is simply easier just to tell the ECM what you want and not try to come up with elaborate schemes to try and fool it.
If your that desperate to do that kind of thing to you engine then I would suggest you PM Unilevers, Mr. Hag, or Gearhead and discuss such possibilities or more proper solutions with them.
