Where can I get the injector leak test tool? Thanks in advance
Del-Ter Machine, Inc.
1038 Triplett Blvd.
Akron, Ohio 44306
delterprecisionmachine.com
Hey makes them
I made my own with an old line . Works great, If your referring to a common rail isx ....
(03-30-2016 )gatow900 Wrote: [ -> ]Del-Ter Machine, Inc.
1038 Triplett Blvd.
Akron, Ohio 44306
Hey makes them
That is the guy I had make mine. He did a great job. You have to use the flat gaskets with his and not the o rings.
Thank you guys i will contact them, great info
I ordered mine from cummins but there are a few guys making them too.
Thanks Rawze I will check with them
