Full Version: ISX fault code
I drove my 2010 Pete 387 for 20 miles
It was idling and suddenly shut down. I used my Nexus mini to scan codes. I got these codes.
I saw some moisture on passenger footrest area. I looked at fuse box behind the glovebox. Some wires actually were wet and some water in fusebox too. I mingled the wiresI found a ground wire cut. I could not find where is coming from. I start the engine and it's idling now. Please help me solve this puzzle. Thank you
[/b]
[attachment=3654]
[attachment=3655]
My guess is you have water leaking in somewhere in your fuse panel. Find where the water is coming in at or how it's getting in there. Electric and moisture are like crack cocaine in an insane asylum. Might be fun for a very short time but chaos ensue's rather quickly. As far as the code, looks like you just shut the key off and run it for a minute and all is good if it goes inactive.
Reference URL's
