https://youtu.be/7Hbv4BovDVA
This will get you started, lightwerks has alot of great videos on how to guides as well as projector and bulb comparisons.
Hi Guy's,
It's been some time since I checked in. Been working on the truck and just about ready to hit the road in July.
I have pulled the interior and gave it a good cleaning, put in dynamat, replaced the floor mats and seats.
attachment=3999]
I have installed the gauges, Pyro, Boost and Load.
attachment=3998]
I also replaced the air springs and all the brake chambers along with inner front fender wells and rear quarter fenders.
I ran the overhead and everything looks good plus replaced some A/C lines and got the A/C going.
I also installed a 2000 watt inverter for power and plan to mount some batteries to the passenger side frame mount for extra capacity.
All in all good progress
Thank you for that info. My fan circuit/system needs to be repaired as the fan is on all the time. I haven't had time to track down what's not working yet. This will help with that process and gives me another way to control it.
Getting closer to the maiden voyage. Had the front tires replaced with Goodyear Marathon LHS's. For now I had them put in the beads. I do want to go to Centramic balancers later now that I know it has 15" drums on the front plus try out the centering studs to true up everything.
attachment=4041]
Got the turbo waste gate actuator replaced, that was a bear to get off with it rusted to the shaft.
attachment=4042]
I also found new replacement headlights made by Doorman for $250 ea with bulbs and harness included. Much nicer with the new lights!
And my trailer got delivered. 2007 Wabash Duraplate in real good condition. I do need to put a couple of tires on it but over all very happy with it
Can't wait to get this truck to a body shop to have the classic bottom of the door rust out repaired.
attachment=4043]
looks good for a Volvo..LOL... very nice work.... but if your going to pull a van trailer are you going to add a OEM faring on the top of that truck?? i'd thing that help out your fuel mileage out alot..
(07-15-2018 )stevesparts Wrote: [ -> ]but if your going to pull a van trailer are you going to add a OEM faring on the top of that truck?? i'd thing that help out your fuel mileage out alot..
For sure. I've documented my mid roof pulling light van trailers and it drops a full MPG+. Mid 7's dropped to low 6's pulling 20,000lbs in the box. I can really feel it struggling when there was a head wind.
