03-23-2018,
I got insite running and I was observing the truck history .. I went on the features and parameters..and I decided to open her up a bit .. changed the idle to 10 min.
.. let the rpm go to 1800 .. instead of 1600 ..
... gave her 70 mph on cruise c only ..
Saved the setting and success .. ran like a champ but !! After about 30 miles the regen light comes on .and it won't regen .. ?? ..
Did a forced regen with insite but temps only get to 800 .. cuz the injector is not turning on ..
I have a lot of codes for egr low voltage egr delta p.. 411 derate .. showing moderate level soot .. ??.. did I do this by. Changing the ecm??
.. can I do a default setting ?? Any advice
