Ultrashift 2012 cascadia clutch groaning when starting from place, especially when heavy. Have replaced the clutch but no changes. What can it be ?
Motor mounts ? Put your hand on the stick , if it moves when you lift its the mounts .
If they did not check them when they did the clutch they need their ass kicked ...
Mine are not in great shape , I am going do a tear down and do the clutch , mounts , rear structure . I just have to find the right time .
I would also check all the bell housing bolts ...
Just seen its a ultra shift .
Pilot bearing, release bearing and input bearing are in that area. Worn input shaft could cause the clutch disc to bind. Loose rivets on the clutch plate can chatter. Just a laundry list of things that can happen.
