I remember from the old site that you can use dimes or pennies to shim the oil pump but how many do you need to to use? My engine is getting a new head and rod and main bearings and want to up the oil preasure wile everything is apart so how many and wich one do I need to use?
Dimes or pennies? Inflation !!!!!
Quarters!!!! If i remember it right four.
attachment=1348][
attachment=1348]
(04-05-2016 )Erics diesel Wrote: [ -> ]I remember from the old site that you can use dimes or pennies to shim the oil pump but how many do you need to to use? My engine is getting a new head and rod and main bearings and want to up the oil preasure wile everything is apart so how many and wich one do I need to use?
Take a look,then check your hardware (spring and plunger for wear.There is a replacement kit available which I posted the number.
Hey when you are done, please come back and tell us how it worked out and what you did.tnx
gearhead has the exact shim measurement - but its more than you think - i believe his was somewhere in the 1/2" range but im sure he will chime in to make sure.
(09-15-2015 )Gadget Wrote: [ -> ]I wanted to follow up on the oil pressure
After I got back to my shop I decided to pull the oil pan and fix the mistake we made with the oil pressure mod.
When I got the pan removed actually dropped down in the front I completely removed the pressure regulator valve from the oil pump, you have to remove one of the mounting bolts and the cotter pin to get the valve out.
[attachment=1351]
As you can see in the picture the spring goes into the cup in the end of the valve I added 6 pennies inside the cup to add tension to the spring. I think you could use more I wasn't interested in huge increase just enough to keep oil pressure at about 40 psi while going down the road at 13-1400 rpms
After adding the pennies (you could also use dimes) I have driven this week and at 1400 rpm and oil temp around 220 I am keeping 40 psi. I am thinking if I did it again I would have used 8 or 9 pennies. The spring is definitely harder to compress and get the cotter pin back in. I got the end cap started then used a torx screwdriver to push the cap in to install the cotter pin.
I don't see a great increase in idle oil pressure but a very solid 20 psi at idle about 650 rpm
I also changed the oil filter bypass with the new cartridge style valve.
I will use 8 pennies and let you guys know what the preasure is like once we get it back on the road hopefully this weekend
I will be shimming mine a bit too, but ...
I would suspect that the more you shimm it, the shorter its lifespan will be as well.- Just some thoughts.
