05-01-2018,
I just got a 2013 KW T660 isx15 cm2250 with approx 500k Miles. When idling seems the turbo is always on? Any input would be greatly appreciated. Thanks
(05-01-2018 )Chinto Wrote: [ -> ]I just got a 2013 KW T660 isx15 cm2250 with approx 500k Miles. When idling seems the turbo is always on? Any input would be greatly appreciated. ThanksI can't help you with your turbo question but I can tell you to either rebuild or buy a new fuel pump for that engine very very soon if you don't know the history of it!! That's about $25,000 worth of advice :big_smile2:
(05-01-2018 )tree98 Wrote: [ -> ](05-01-2018 )Chinto Wrote: [ -> ]I just got a 2013 KW T660 isx15 cm2250 with approx 500k Miles. When idling seems the turbo is always on? Any input would be greatly appreciated. ThanksI can't help you with your turbo question but I can tell you to either rebuild or buy a new fuel pump for that engine very very soon if you don't know the history of it!! That's about $25,000 worth of advice :big_smile2:
(05-01-2018 )Evotrucker Wrote: [ -> ]yep, tree98 is right, I have a 2013 cm2250 that I am currently disassembling and flushing and hoping its salvageable ... only 200,000 miles ... ate the ceramic dumb*ss plungers!!!!(05-01-2018 )tree98 Wrote: [ -> ](05-01-2018 )Chinto Wrote: [ -> ]I just got a 2013 KW T660 isx15 cm2250 with approx 500k Miles. When idling seems the turbo is always on? Any input would be greatly appreciated. ThanksI can't help you with your turbo question but I can tell you to either rebuild or buy a new fuel pump for that engine very very soon if you don't know the history of it!! That's about $25,000 worth of advice :big_smile2:
i like history, care to share some history? :D
(05-01-2018 )Evotrucker Wrote: [ -> ](05-01-2018 )tree98 Wrote: [ -> ](05-01-2018 )Chinto Wrote: [ -> ]I just got a 2013 KW T660 isx15 cm2250 with approx 500k Miles. When idling seems the turbo is always on? Any input would be greatly appreciated. ThanksI can't help you with your turbo question but I can tell you to either rebuild or buy a new fuel pump for that engine very very soon if you don't know the history of it!! That's about $25,000 worth of advice :big_smile2:
