Insite says ECM warning internal hardware failure - bad intelligent device or component. The driver said the truck ran fine all gauges read normal. It's now inactive with 1 count. Any idea's ?
(05-25-2018 )tree98 Wrote: [ -> ]Insite says ECM warning internal hardware failure - bad intelligent device or component. The driver said the truck ran fine all gauges read normal. It's now inactive with 1 count. Any idea's ?
What year make model truck? mileage? some history and detail?
2018 Pete 365 (crane truck) cm2350 9,000 miles, factory original mandate.
(05-25-2018 )tree98 Wrote: [ -> ]2018 Pete 365 (crane truck) cm2350 9,000 miles, factory original mandate.
If it sits a lot, maybe a ground wire or corrosion in a power supply somewhere? -- could also be battery backed mem module in ECM going bad and loosing memory if it sits a lot?.
Just some abstract guessing here.
Possibly have it re-flashed and see if it goes away?.
(05-25-2018 )tree98 Wrote: [ -> ]Can I reflash it myself?
2018? not under warranty?
(05-25-2018 )imalumberjack Wrote: [ -> ] (05-25-2018 )tree98 Wrote: [ -> ]Can I reflash it myself?
It's under warranty but they aren't going to re flash it just because I ask them to. And I don't really want to take it there and let it sit for a week until they get around to poking and prodding it.
