I don't really have away on steam cleaning the engine. i don't think this shop does either its a small shop by st louis. but im have them check the filter under pressure make sure the seal isn't leaking or somthing
Get a case of brake clean then and start hosing off the oil. Degreaser and a garden hose. You need to clean it up some how. Get creative.
Well its caused by Blow by.. White smoke is pouring out the exhaust and blow by and oil fill tube.
Before making the sign of the cross, isolate the turbo, make sure you don't have a blown shaft seal.
(07-23-2018 )Moose Wrote: [ -> ]Before making the sign of the cross, isolate the turbo, make sure you don't have a blown shaft seal.
That was the first thing the shop did this morning.
Here is the video of the blow by
https://youtu.be/DXZmB8W-cRY
(07-23-2018 )Pete1990 Wrote: [ -> ] (07-23-2018 )Moose Wrote: [ -> ]Before making the sign of the cross, isolate the turbo, make sure you don't have a blown shaft seal.
A cracked piston will do that.
Hory shet.....
My most heartfelt apologies.
(07-23-2018 )Rawze Wrote: [ -> ] (07-23-2018 )Pete1990 Wrote: [ -> ] (07-23-2018 )Moose Wrote: [ -> ]Before making the sign of the cross, isolate the turbo, make sure you don't have a blown shaft seal.
Hate to confirm. My did absolutely same.
I'm sorry about that but you have a hole in one of your pistons.
