04-17-2016,
Ok, so i have taken the weekend off while waiting for counterbore shims. I am counter-boring my block myself because I found the exhaust side of cylinder number 6 to be 0.002" low. It is no big deal,.. but it is just enough that I do not think it will last another million without some help. I will also be raising the height of all the liners to 0.014" from the factory 0.010" that it was. This should make it stout, and/or allow me to put some serious horsepower in it if I choose in the future if I ever want to.
Who said a gallon of gear lube in your engine is bad?-.. I think this is clear proof! --- all these parts still look new!. I have always used regular Rotella-T oil with one gallon of Sta-lube 80/90 gear at every oil change.
Here are my rod bearings after 955,000 miles...
[attachment=1382]
And the cams after 955,000 miles... Hard to see in picture, but there is actually ZERO WEAR THAT CAN BE MEASURED with a set of calipers. Only just beginning to polish on some lobe surfaces.
[attachment=1383]
Rollers and some crossheads...
[attachment=1384]
Here is the worst of all the wear I could find... If someone asked me to look at this,.. I would swear it was only about 400k miles on that bearing.
[attachment=1385]
-- the IRONY in all this,..--- Is that These parts HAVE NOT BEEN CLEANED YET! -- AT ALL!... But simply removed form the engine and placed onto the table. there are no deposits anywhere,.. and there was only a tiny piece of dried loc-tite in the bottom of the oil pan. There was not even any glitter in it. It was absolutely clean. -- Even the magnets are clean!.
[attachment=1382]
[attachment=1383]
[attachment=1384]
[attachment=1385]
