Full Version: Fuel injector Test .. thoughts ???
Pages: 1 2
(08-30-2018 )Rawze Wrote: [ -> ]I don't care how much you "trust" the guy who made the de-mandate program. If it was not someone officially recommended by this forum then you need to pull a copy of that program out of that ECM ASAP! and have myself or one of those guys look at it to ensure it is safe. -- Otherwise you are only fooling yourself and taking a gamble where the odds are 90+% AGAINST you having a decent program. Don't be the next victim of a bad delete like all the hundreds and hundreds of fools that said, swore their engine was running great, exactly what you just said, only to cry later as their engine ate itself to death internally.
http://rawze.com/forums/showthread.php?t...5#pid13255
. I appreciate your time and help Rawze .
I have a 2012 ISX CM2250 , has 615xxx . As of today its running "Great" , I understand these are pictures but I still value your time and opinion about them . Let me know what you think and thanks again for what you do for O/O community .
couple more pics ..
(06-08-2019 )JHNDZ Wrote: [ -> ]
IF YOU VALUED MY TIME THEN YOUR WOULD HAVE LISTNEND TO ME ---
I REPEAT MYSELF!!!! BECAUSE YOU VALUE MY OPINIONS, YET CHOOSE TO IGNORE THEM LIKE SOMEONE WHO WANTS TO LIVE IN SOME FANTASY WORLD!!! !!!! --->
SOME PEOPLE HAVE TO LEARN THE HARD WAY AFTER THEY TEAR UP THEIR ENGINE!!!
-- THAT IS MY "VALUED OPINION", AND IF YOU DISAGREE THEN YOU ARE THE NEXT VICTIM THAT IS GOING TO LEARN THE HARD WAY!!!,.. OR ARE YOU JUST TOO GODDAMN STUBBORN TO REALIZE IT!!!
AND ACCORDING TO WHAT YOU POSTED, YOU NOW ALSO HAVE 100%, THE WRONG PROGRAM IN YOUR ECM TOO!!!!! --- THE FILE YOU ARE SHOWING DOES NOT EVEN HAVE THE SAME DAMN HARDWARE FOR YOUR ENGINE,.. WRONG CPL, WRONG INJECTORS, WRONG CAC UNIT, WRONG EVERYTHING!! -- AND IF YOUR SUPER-DUPER MECHANIC WAS SO GODDAMN GOOD AT WHAT HE DOES, THEN HE WOULD HAVE SEEN THAT SH#IT RIGHT AWAY!!!! -- FIRE YOUR MECHANIC WHEN IT COMES TO BAD PROGRAMMING, BECAUSE THAT IS EXACTLY WHAT YOU GOT IN THAT THING!!! -- THE WRONG TIER PROGRAM IN IT, BAD DELETE OR NOT!!!.
-- I don't care how you "think" your engine is running!!! --- PLAIN AND SIMPLE!!!
-- THAT 10053 CALIBRATION AND ITS ADVERTISED (BUT NOT LIKELY ACTUAL) POWER AND TORQUE SETTINGS ALSO LOOKS EXACTLY JUST LIKE THAT P.O.S. GARBAGE PROGRAM THAT HAS BEEN PASSED AROUND ON THE INTERNET TRUCK-TUNING SITES THAT PEOPLE ARE USING TO MAKE BAD DELETES, AND COPIES THEREOF!!! -- BUT UNTIL YOU PULL IT AND HAVE THE PROGRAM INSPECTED LIKE I SUGGESTED, YOU WILL NOT KNOW, BUT REGARDLESS, YOU HAVE THE WRONG CPL PROGRAM IN IT SO IT HAS TO BE FIXED ANY WAYS!!!
Also, the picture is blurry. But the 2nd pic down, in the lower left corner, the cam lobe looks to be chewed up. It could be the shadow. But it definitely has the look of a scrubbed lobe.
I see those lobes too chamberplains...2 look to be starting to flatten out.
Pages: 1 2
Reference URL's
