Hi,i got 2011 prostar,i would like to change speed ,but it has password,could anybody help with that,thanks lot
I can't speak about yours but the company i purchased mine from uses the last 6 of the VIN as the password.
i try last 4 of the vin,last 6 of the vin,000000 ,555555 all what i find is not working,only dealer or there is reset programms?
(09-29-2018 )turisto Wrote: [ -> ]Hi,i got 2011 prostar,i would like to change speed ,but it has password,could anybody help with that,thanks lot
Insite 7.6 passwrod removal tool can disable it. Is one of the menu options under "Tools" -> "ECM Password Removal". Maybe is greyed out then you need to activate it in options ->security -> ecm password removal. Use add button and put in proper security code to activate it.
