I have competed a blow by test for my ISX871 850K (Correction..it has a second motor mileage supposedly 600k)
As per Rawzes blow by test video. As I increased my rpm slowly to 1500 the difference in the water level kept increasing and oil was coming out of the dipstick. I have checked for the usual blockage related stuff...crankcase filter..blow by drain tube..etc
What can cause continual building of crankcase pressure? I suspect the turbo but how would I test for that? I have not performed a compression test. Engine runs smooth. I performed a cylinder cut out test with Insite and it seemed okay. I'm at a loss!
(11-08-2018 )Makmak Wrote: [ -> ]I have competed a blow by test for my ISX871 850K mileage.
maybe drill out the crank case filter so it can;t build pressure and hurt the turbo?
(11-08-2018 )Rawze Wrote: [ -> ] (11-08-2018 )Makmak Wrote: [ -> ]I have competed a blow by test for my ISX871 850K mileage.
I have already drilled a hole in the CC filter. While doing the blow by test all that was bypassed as you know. What is the max size file size of a video I can upload to here?
Upload it to YouTube and then post a link on here.
i do beleive an air compressor can also throw pressure into CC
(11-13-2018 )Lonestar10 Wrote: [ -> ]i do beleive an air compressor can also throw pressure into CC
I checked yesterday I do have oil coming out of the compressor discharge port.
(11-15-2018 )Makmak Wrote: [ -> ] (11-13-2018 )Lonestar10 Wrote: [ -> ]i do beleive an air compressor can also throw pressure into CC
that could cause a lot of issues with the air systems later on.
