11-10-2018,
Oil pressure before and after the filter is
15psi out of the block from the oil pump to the filter and 8psi out of the filter.
(11-10-2018 )snailexpress Wrote: [ -> ](11-10-2018 )Peashooter67 Wrote: [ -> ]After I check the air compressor, change oil cooler, check gears in gear case with no solution I guess it get dead headed back up to Oklahoma to the dealer for warranty.
I know I can’t drivr/run it like this.
Just my though. What if you have piece of rubber from destroyed oil filter O-ring somewhere in the oil sensor port?
(11-10-2018 )Peashooter67 Wrote: [ -> ]Thank you rawz for your help in narrowing down and verifying my issues.
I fear what I’ll have is a pile of new parts and a bad block......
Supposed to have 12/100,000 mile warranty on motor so if Block is cracked I will be putting it back together and driving it back to Cummins dealer where I bought it and make them replace block and if they refuse legal action and I’ll bring it back home and repower it with a pre emissions 14.7 Detroit. It’s a much better motor and this is coming from a caterpillar guy. I’d go with a cat but 6nz cats are way expensive.
(11-09-2018 )Rawze Wrote: [ -> ]Only thing that can cause oil pressure to be that low (8 psi) that I can think of it that it is likely internally homoraging oil badly somewhere. That or the oil filter is plugged up?
Common mistakes during an inframe just some random guesses here. Some of this it sounds like you have ruled out already ...
* oil pump shimms installed incorrectly (upside down), allowing oil to leak past them. Seen that one a few times.
* bad oil pump? - I have seen new ones with problems sometimes. Taking it apart will reveal what is wrong if it is bad internally.
* Oil filter bypass valve update installed incorrectly or o-ring shear.
* Bad oil cooler?, leaking internally?. not sure if thats possible, Have not had to take mine out yet.
* A spun bearing somewhere.
* incorrectly fitting, or damaged piston cooling nozzles.
* Bad o-ring in pickup tube, oil pump sucking air?.
* Damaged oil pump.
* Damaged internal passage in engine block?
* Air compressor bypassing too much oil ?
* The lower concept idler gear (first gear above the crank) is also positive pressure feed. A bad bearing / misalignment of sort could cause problem / low oil pressure too. The adjustable idler gear is also positive pressure fed.
* has anyone eliminated the turbo oil feed line temporarily to make sure it is not bleeding too much oil through it?
What brand of rod/main bearings were used? OEM or aftermarket?. Anyone plasitgauge the bearings for excess clearances?
(11-15-2018 )Peashooter67 Wrote: [ -> ]Rawze sir
Oil journal pressure tests are done. Good news........ no cracks...
Doing plastigauge on rod and mains this week.
Sir
Is the creances on both rod and main bearings .002-.003?
