(02-03-2020 )Peashooter67 Wrote: [ -> ]WELLLLLL!!!!!!!!!!!!
A little over 101,xxx miles on rebuild and my engine is trashed.
Front crank bushing / bearing went out. I don’t have the motor open yet but I’m 99% certain there is little metal flakes run all through the motor.
Can’t wait to open it up and figure out what happened.
Sssoooooooooooooooo........... here is the million dollar question?????????
I’m buying a used running low mileage motor and pulling this one out for core.
What is in the truck is a cummins isx cm870 .....
What should I put back in its place?
Front crank bearing would have never gone out if someone had done the job properly.
it sounds to me like the engine was doomed from the start. - A OE stealer$shi#t rebuilt it (the worst place it could have been done at),.. oil pressures problems right off the bat, and a lot of other red flags typical of a shop niot knowing squat on how to properly inframe the engine.
Also, the shop that tried to help you, they are clueless too ...
I hope like hell you found a different, BETTER shop for helping you with this and not the same complete idiots you dealt with the last time.
it also sounds to me like your just one of those guys who will keep picking at their opwn scabs and keep making bad decisions, relying on "freshly inframed" and "used engines" and all sorts of other things that will put you in the hole deeper and deeper.
-- If i Owned a truck that the block was trashed like that on ..
I would buy a certified OE short-blockjust for the components, tear it down, counter-bore it, set liner height to 0.014" (reference:
http://rawze.com/forums/showthread.php?t...1#pid11611 ), put a brand new head on it, and take the old stuff off the old engine that was still good,.. so that AT LEAST 'I KNEW WITHOUT ANY SHADOW OF ANY DOUBT' about how well it was built,.. and knew EXACTLY WHAT I HAD and that it could be trusted for the next million miles,.. even if it had cost me 2x as much because THERE IS NOT ANY PROFIT IN DOING THINGS --- YET AGAIN IN A COUPLE YEARS!!!.
-- Sorry for putting it in harsh words,.. but -- I AM NOT OUT HERE ON THE ORADS TO JUMP OVER A DOLLAR JUST TO SAVE A DIME.. ... I AM HERE TO MAKE AN ACTUAL LONG TERM PROFIT I CAN KEEP AND NOT HAVE TO WORRY ABOUT QUESTIONABLE, UNRELIABLE, USED, OR SHOTTY WORKMANSHIP OR ENGINES AND VEHICLES I CANNOT RELY ON BECAUSE THEY WERE HALF-ARSSED!
I ALSO WOULD NOT LET ANY SHOP ANYWHERE NEAR MY TRUCK OR ITS ENGINE IF THEY DID NOT KNOW AS MUCH ABOUT IT AS THE PROFESSIONALS ON THIS FORUM DO -- I DO NOT HAVE A BUDGET PLAN FOR SOMEONE ELSE'S IGNORANCE, NOR AM I WILLING TO PAY FOR THEIR EDUCATION!
HERE is a mighty fine example of this, how bad these shops really are, and why people have nothing but problems any more out of their trucks and engines. ...
http://rawze.com/forums/showthread.php?t...6#pid25356
