05-02-2016,
Anyone see this? Looks like the bulletin came out last October. I don't know how to link the bulletin here, so I just copy and pasted it. The bulletin number is TSB150147. Got it off of Quickserve. Curious what people think. Good idea? Or hogwash?
Technical Service Bulletin Number
TSB150147
QuickServe Online
Cummins Inc.
Subject
New Maintenance-Free Crankcase Breather Insert
Warranty Statement
The information in this document has no effect on present warranty coverage or repair practices, nor does it authorize TRP or Campaign actions.
Contents
Product Affected
ISX15 CM871
ISX15 CM2250
ISX15 CM2350 X101
Description of Change
This document announces the release of a maintenance-free crankcase breather insert for external crankcase breather systems and advises the field of a part number change for the existing crankcase breather filter element.
The new maintenance-free crankcase breather insert is a direct fit replacement for the existing crankcase breather filter element but does not require a filtration media to function.
Reason for Change
The maintenance-free crankcase breather insert has been released to eliminate the need for scheduled replacement of the existing crankcase breather filter element and reduce associated maintenance costs.
Customer Communication
The crankcase breather filter element that requires replacement at regular maintenance intervals is not being obsoleted. This is being done in support of customers that want to continue to use the previous design and do not want to convert to the new maintenance free design.
Service Parts Availability
Service parts are available. See Table 1 below for part numbers.
Table 1, Crankcase Breather Element Part Numbers
Part Description
Obsolete Part Number
New Part Number
Not Applicable
3691476
Crankcase Breather Filter Element
4312013
3691687
Part Compatibility
The maintenance-free crankcase breather insert, Part Number 3691476, is a direct fit replacement of the existing crankcase breather filter element. No changes to the crankcase breather housing are required.
Part Structure
Crankcase breather filter element, Part Number 4312013, has been obsoleted and is superseded by crankcase breather filter element, Part Number 3691687.
Part Inventory Action
Use existing crankcase breather filter element, Part Number 4312013, inventory before using the new part number 3691687.
Production Status
Parts have been released for production. See Table 2 below.
Table 2, Plant Information
New Part Number
Engine Serial Number First
Build Date*
Plant
3691476
79877075
28 September 2015
Jamestown Engine Plant
*Engine build date can be found on the engine dataplate.
Date Details
2015-8-31 Module Created
2015-10-19 Non-Product Problem Solving (PPS)
Last Modified: 29-Oct-2015
Feedback / Help
Copyright © 2000-2010 Cummins Inc. All rights reserved.
TSB150147
QuickServe Online
Cummins Inc.
Subject
Warranty Statement
Contents
Product Affected
ISX15 CM871
ISX15 CM2250
ISX15 CM2350 X101
Reason for Change
Part Description
New Part Number
Not Applicable
3691476
4312013
3691687
Part Compatibility
Part Structure
Production Status
New Part Number
Build Date*
Plant
3691476
79877075
28 September 2015
Date Details
Feedback / Help
