Really do not want to purchase a new fuel tank the skirts have worn in the area about 3 inches wide and 2 inches tall. I really want to try a product such as J-B Weld to fix it but wondering if there's anything else similar that would be better maybe I can find someone to weld it... thank
Let me clarify the skirts Wore a depression into the tank where are the aluminum is now very thin in that location and is cracked on each end and leaking
I think my original post may have sounded like there was A3 by 2 hole and that is not the case it is a depression
(05-03-2016 )jan0272 Wrote: [ -> ]Really do not want to purchase a new fuel tank the skirts have worn in the area about 3 inches wide and 2 inches tall. I really want to try a product such as J-B Weld to fix it but wondering if there's anything else similar that would be better maybe I can find someone to weld it... thank
I think I would find a place to get a patch welded over it. You might be able to find one reasonable priced at a bone yard.
Don't waste your time trying to patch it with JB unless it's just to get you home. 100- 150 gl tank runs about $350 from a scrapper. You have to drain and flush it anyway to Heliarc.
Ok how bout some suggestions on where to find a tank, I'm in Florida needs to be a rear fill 100 gal. KW T2000
lkqcorp actually has a fuel tank for a 2001 t2000 in stock...
(05-04-2016 )Nilao Wrote: [ -> ]What part of Florida?
Jacksonville area, thanks.
