Full Version: Cam gear torque
Does anybody know what the cam gear bolt torque is?
Tighten the injector camshaft non-scissor gear retaining capscrew.
1. 136 n•m [ 100 ft-lb ]
2. Rotate an additional 90 degrees
Loosen the capscrew 360 degrees and tighten again using the torque-plus-angle method.
Torque Value:
And DO NOT FORGET to...
The valve camshaft nose and valve camshaft gear must be clean and dry prior to assembly. Wipe off the taper surface with a clean, lint-free cloth and apply a thin coat of Loctite™ 609, Part Number 3823718, to the inside diameter of the camshaft gear. Use care not to contaminate the joint with oil prior to assembly or engine damage may occur.
Apply a thin coat of Loctite™ 609, Part Number 3823718, to the inside diameter of the camshaft gear.
609 was not used on my first in frame, the injector cam gear jumped a tooth and was coming apart, it was the two piece scissor gear. We replaced with a solid gear and 609 was applied as instructed in the Quickserve manual.
Thanks for the info that is the only thing I didn't put on is609 your right it did not state it.
Reference URL's
