Oh, when replacing sensors, lube the o ring with either Vasoline or anti-seize. Makes install much easier and less chance of damaging the o rings.
https://www.matcotools.com/catalog/produ...VER-GREEN/
I have a 30 inch version of this with the tip ground a little sharper.
You walk the tip around the base twisting slightly and try to walk it out evenly. Usually pops right out once you get it to a fully twist of screws driver head.
Take your time don't get frustrated and DO NOT PRY ON IT WITH A PRY BAR....
When you get good at them they only take a few minutes to do. Guess I owe a thanks to the old 444e motor and that high failure part.
Yeah the 444e is the 7-3 in pickups
