07-17-2019,
(03-02-2019 )alborz Wrote: [ -> ](02-28-2019 )Chamberpains Wrote: [ -> ]You're gonna want to search Cummins Insite version 7.6.2 and a cummins Inline 5 or 6 adapter. The adapters usually come with the Insite software but you'll want to make sure it comes with version 7.6.2 stay away from version 8 and above or newer for they are paid subscription. You'll also want a laptop with windows 7 or newer. It is a tool now so have it dedicated to your truck diagnosing software only.
Cheapest way to collect all the above would be clean up and clean install an old laptop someone may have and go to eBay (chinese knockoffs are working just fine for a lot of us) or google search the adapter for the Inline adapter. You can spend a couple hundred $$ and be up and running real easy.
How much this insite cost?
I search on the Ebay but couldn't find this version.
i went to ODB2Tool.COM and typed inline 6 got it ordered $188.00
