03-14-2019,
Hey all,
I just put another dryer on my 2010 T2. Long story short, I started noticing alot of moisture again in my tanks, and my purge valve started leaking. Its the second new one Ive installed in 2 years. New bendix. I also replaced the reservoir since it is under the truck on mine was was rather tattered looking.
I do tend to run local lot, so Ive considered the humidity in savannah. Im seeing about 150 miles avg per day, lots of idle time. Would you guys consider this a normal lifespan for a dryer in a humid environment? Im also considering replacing the cartridge more often to see if it helps, maybe biannually.
Just trying to keep up with it until inframe time, which will probably be soon. Its starting to bubble a little bit into the coolant reservoir when idling.
