05-09-2019,
100k ago I rolled in mains and rods, among other repairs, in order to get more life out of my 871 when I repaired a flat cam. Been running fine for the most part ever since.
Today I checked the oil during my pretrip and was bummed to find metal. Not a ton of it...very small pieces of it...but I did get one noticeable flake of metal. Bummer. Oil pressure is 40-43 hot at speed, idle is around 18 hot. It did get 6 dimes last time it was apart. Whatever is causing it just started.
I guess im going to be taking it home so I can pull the VC and drop the pan...do a rod and main inspection, inspect the pump and valvetrain for the source. Ill also be doing a leakdown test (fuel mileage)and check the head again for wear.
Since this is definitely not normal, nor do I care to junk an engine, at 784k miles, is there anything I might need to pay attention to other than the obvious?
Its got @m*m^2 and frequent oil changes with gear lube as an additive. Bypass filtration with a filtermag on the full flow. Still runs normal, not noisier than usual. I keep getting intermittent low coolant alarms though the cooling system is not low/holds pressure and the wiring and sensor is new...Ive attributed that to the age of the engine. Turbo/compressor are recent and its up to date on all maintenance items.
