Thank you guys, will do that. Let you know then if it's fix my problem or not. Also do you know how I can check metering and fuel actuators if they working properly? If there is a voltage drop or resistance. Thank you in advance.
Is it definitely a misfire? The cm570s run slightly rough and have an uneven idle at the best of times.
(05-13-2019 )Signature620 Wrote: [ -> ]Is it definitely a misfire? The cm570s run slightly rough and have an uneven idle at the best of times.
Yes, I can feel and hear it under the load, it works fine before.
