I get the same message when using CT for too long, if I let the screensaver turn on, or the inline just says I'm done for now. Yup, gotta back out. DISCONNECT (it's the important part) from the data port and start over. I have a J1708 port on my intertrashional. So up or downloading is a minimum 45 minute task. Its always a guessing game of whether it will be 45 min or 4hrs with multiple tries and start overs.
Does Insite work with the Nexiq usb link (authentic)??
(11-21-2020 )hookliftpete Wrote: [ -> ]Yep, that’s what I use.
What is the source for insite?
I thought it was a super expensive "subscription" based program?
thanks.
(11-22-2020 )rolling18 Wrote: [ -> ] (11-21-2020 )hookliftpete Wrote: [ -> ]Yep, that’s what I use.
thanks.
That is correct if for some reason you want a legitimate version of the program. Software trading in the open is against the rules of the forum. Buy some crafty Googling will get you what you need.
