08-22-2019,
(08-22-2019 )smorgan87 Wrote: [ -> ]Thats a rod hanging out the side of a 2350 blockAnd that came from a bad delete????
(08-22-2019 )smorgan87 Wrote: [ -> ]Yessir. Can hammer out bearings. Once that happens the slack will in turn cause more problems and break off rod bolts/studs. But hey! It pulled like a freight train! That means its a good delete. ;)Wow!!!!! Hopefully I won't have the same misfortune.....getting it done tomorrow
(08-22-2019 )david24 Wrote: [ -> ](08-22-2019 )smorgan87 Wrote: [ -> ]Yessir. Can hammer out bearings. Once that happens the slack will in turn cause more problems and break off rod bolts/studs. But hey! It pulled like a freight train! That means its a good delete. ;)Wow!!!!! Hopefully I won't have the same misfortune.....getting it done tomorrow
(08-22-2019 )tree98 Wrote: [ -> ]A guy in Griffin, GA that's highly recommended on this forum(08-22-2019 )david24 Wrote: [ -> ](08-22-2019 )smorgan87 Wrote: [ -> ]Yessir. Can hammer out bearings. Once that happens the slack will in turn cause more problems and break off rod bolts/studs. But hey! It pulled like a freight train! That means its a good delete. ;)Wow!!!!! Hopefully I won't have the same misfortune.....getting it done tomorrow
Who's doing yours?
(08-22-2019 )david24 Wrote: [ -> ](08-22-2019 )tree98 Wrote: [ -> ]A guy in Griffin, GA that's highly recommended on this forum(08-22-2019 )david24 Wrote: [ -> ](08-22-2019 )smorgan87 Wrote: [ -> ]Yessir. Can hammer out bearings. Once that happens the slack will in turn cause more problems and break off rod bolts/studs. But hey! It pulled like a freight train! That means its a good delete. ;)Wow!!!!! Hopefully I won't have the same misfortune.....getting it done tomorrow
Who's doing yours?
(08-22-2019 )tree98 Wrote: [ -> ]That's what I've been told(08-22-2019 )david24 Wrote: [ -> ](08-22-2019 )tree98 Wrote: [ -> ]A guy in Griffin, GA that's highly recommended on this forum(08-22-2019 )david24 Wrote: [ -> ](08-22-2019 )smorgan87 Wrote: [ -> ]Yessir. Can hammer out bearings. Once that happens the slack will in turn cause more problems and break off rod bolts/studs. But hey! It pulled like a freight train! That means its a good delete. ;)Wow!!!!! Hopefully I won't have the same misfortune.....getting it done tomorrow
Who's doing yours?
Well then obviously you'll be just fine :big_smile2::
