08-26-2019,
Pages: 1 2
08-26-2019,
some factory radios have an input for qualcomm device, so that the sound will come through the speakers above the sound of the radio. It could be that.
However: you mentioned that it is a green and yellow wire. It is quite common for devices to have Green and yellow pair of wires for the CAN+ and CAN-, J1939 connection. Roughly 2.5~ish volts or thereabouts on one (or both) wires when measured would also point it in this direction too.
Only way to find out for sure is to get the cab wiring diagram for your make/model truck and look it up. Last thing someone needs is to make an assumption and fry things.
08-26-2019,
(08-26-2019 )Rawze Wrote: [ -> ]some factory radios have an input for qualcomm device, so that the sound will come through the speakers above the sound of the radio. It could be that.
Yeah. Don’t need no assumptions and fry something. I’ll dig a little deeper this weekend and see if I can trace the wires to see where they go. Who knows. If it is j1939 would it be bad just to leave them unhooked? That’s how they are now. Was a butchers paradise before I got in there and straightened things out other than those two wires.
08-26-2019,
Post a picture on here might give us a better idea of what and where it goes to.
08-26-2019,
(08-26-2019 )marek4792 Wrote: [ -> ]Post a picture on here might give us a better idea of what and where it goes to.
K. I’ll try to get it tomorrow
08-27-2019,
Here is pic of wires
08-27-2019,
(08-27-2019 )Soulreaver0102 Wrote: [ -> ]Here is pic of wires
that looks exactly like the j1939
08-27-2019,
(08-27-2019 )Rawze Wrote: [ -> ](08-27-2019 )Soulreaver0102 Wrote: [ -> ]Here is pic of wires
I thought same thing couple hours ago. I had to pull my cluster and same wires ran to it and to the hvac controls as well so I figured that’s what it was. So what should I do with them. Leave them as they are? And thanks for the reply.
Pages: 1 2
