01-07-2020,
Why not pull the head and cut the counter bores now before you go any further? Surely it will be a problem later.
(01-07-2020 )tree98 Wrote: [ -> ]Why not pull the head and cut the counter bores now before you go any further? Surely it will be a problem later.I never intended to tear this motor down, nor do I want to now, talking with the mechanic I'd like to believe he is being honest. I dont want to tear apart what could be a perfectly good build and waste thousands of dollars just for fun when I could be out in the field in my other unit.
(01-07-2020 )Brock Wrote: [ -> ](01-07-2020 )tree98 Wrote: [ -> ]Why not pull the head and cut the counter bores now before you go any further? Surely it will be a problem later.I never intended to tear this motor down, nor do I want to now, talking with the mechanic I'd like to believe he is being honest. I dont want to tear apart what could be a perfectly good build and waste thousands of dollars just for fun when I could be out in the field in my other unit.
Might bite me in the ars, when I cut corners it usually does.
(01-10-2020 )Brock Wrote: [ -> ]Lipe clutch installed and Transmission on motor, shes going into the truck on Monday!!
(01-12-2020 )Moose Wrote: [ -> ]So I saw the post on FB about this and the narrow-minded, ill-informed "If It'S nOt A cAt It'S a DoG" mentality is still alive and well. Pretty sad and some of them were comical even without the grammatical errors. You do what's right for you and YOUR business. Just sell the SDP to some cat-tard for a stupid amount of money and know you did the right thing.
