06-16-2016,
Hey guys, hope my experience helps someone. I'm broke down, and waiting for a service truck... Took the truck and trailer (company trailer) in for a DOT inspection. Truck was fine, trailer had a bad air line spring so we replaced it. Well, the idiot that put the new spring on did not properly secure it. This is an actual mechanic, supposedly, so I did not think of crawling under the trailer in their greasy ass shop or in the piss filled parking lot to inspect the damn spring. How hard is it to properly secure a spring?
Anyways, the damn spring came lose on my way to the airport last night to meet a plane with critical freight for Chrysler. I almost made it, 4 miles to go and the air buzzers are going off. I pulled over at my get off ramp and found the trailer airlines dragging the ground. Two holes in the hoses, electrical cable wiped out. I nursed her into the truck stop at the exit to get off the road, 300 yards at a time... I grabbed a wrench and dove under the trailer and guess what? Only one caging bolt on one brake can. The other three were GONE!
So, take a look at your brake cans and make sure the caging bolts are there... And I bet I can guess where the bolts are that should be on this trailer, in some shops garbage can... Check your brake cans.
I'll be purchasing some caging bolts and throwing them in my tool bag.
O'Rielly Automotive Stores carry them, $3.69ea or you can order from here @ $4.75ea http://www.ryderfleetproducts.com/haldex...-p-u55-rt1
Oh, I have them on my tractor cans, but I have not yet lost enough weight to shimmy under there!
