I have a 2350a isx15 Cummins and I am getting a spn code of 459019 . Can anyone tell me what this code means? I can't seem to find it anywhere. Thanks
(01-15-2020 )Cwmartinjr Wrote: [ -> ]I have a 2350a isx15 Cummins and I am getting a spn code of 459019 . Can anyone tell me what this code means? I can't seem to find it anywhere. Thanks
Go to
https://quickserve.cummins.com/ set up a free account and register your engine serial number. Then you can use the fault code search under the service tab to look it up. You'll need both the SPN and FMI. Then once you find the cummins code you'll also be able to see the troubleshooting and repair procedures as well. You can also look up part numbers through there, download user and service manuals, and more. All for free.
Thank you for your help. I have done setup up everything and it's a great site but for some reason that spn code doesn't show up. Weird.
(01-16-2020 )Cwmartinjr Wrote: [ -> ]Thank you for your help. I have done setup up everything and it's a great site but for some reason that spn code doesn't show up. Weird.
Maybe that is a cab controller warning, vehicle specific? I tried looking up that code you posted and normally they will pop right up, no luck with that number on my end.
