Hey guys real quick do you know if my 2011 Prostar has wiring for chicken/clearance lights like a pete does? Or would I have to wire them into the existing light wiring so they come on with the side markers? Thanks in advance.
My '09 has a switch on the dash that says 'spare' and is connected to nothing; it's what I would use. If you don't have a switch like that, add one yourself, or like you said - wire them into the existing...
Look behind the panel below your bunk or under your drivers door for a plug. Also pull out your panel with your switches and look for a plug that isnt plugged in that says marker lights or skirt lights..
Odds are it's all there.
