I have had Insite for 2 years , Which it just expired again, before I renew
Is there an old Version of Insite out there that does not have to be renewed that will allow me to change Parameters, Reset Trip Data, Etc.
Even upload Calibrations?
A great big thank-you to Running Rough for helping me out today. he's a real solid guy.
Its great to have someone like that on this forum.
(01-30-2020 )Smooth Wrote: [ -> ]I have had Insite for 2 years , Which it just expired again, before I renew
Did you end up finding an older version of Insite? I'm looking to get setup with insite for the first time and wondering what you learned? Thanks
I installed insite 7.6 on my laptop back in 2011 using the sultan keymaker. has never had an iaaue, is basic, pro, pro plus, everythng dealer hass. - It says will not expire until the year 2027.
the cat has been out of the bag on insite 7.6 for many years ans is all over internet + that keymaker all for free. just gotta look in the right places for it.
(02-13-2020 )MageRoyal Wrote: [ -> ]I installed insite 7.6 on my laptop back in 2011 using the sultan keymaker. has never had an iaaue, is basic, pro, pro plus, everythng dealer hass. - It says will not expire until the year 2027.
I went this same route, although I had to manually set my laptop's calendar to 2013 to get it working. supposedly there's another program that can remedy this, but I don't know where to find that.
If you search, try 'keygen' instead of 'keymaker'
(02-13-2020 )JimT Wrote: [ -> ] (02-13-2020 )MageRoyal Wrote: [ -> ]I installed insite 7.6 on my laptop back in 2011 using the sultan keymaker. has never had an iaaue, is basic, pro, pro plus, everythng dealer hass. - It says will not expire until the year 2027.
no need to make date change if u followed correct procedures for it. u musta missed somethin.
(02-13-2020 )Rawze Wrote: [ -> ] (02-13-2020 )JimT Wrote: [ -> ] (02-13-2020 )MageRoyal Wrote: [ -> ]I installed insite 7.6 on my laptop back in 2011 using the sultan keymaker. has never had an iaaue, is basic, pro, pro plus, everythng dealer hass. - It says will not expire until the year 2027.
I bought inline from eBay, the rest I googled and downloaded with no instructions. The program that I've seen others use to set the time wasn't included and Google wasn't helping.
quoted from another forum back in 2015 ...
Quote: installed 7.6.0 ver. and after that he went to update manager and updated it by choosing CDROM on the update manager as the source. cd had 7.6 on it.
after that. it was at 7.6.2
he then applied the 'Update7_06_2_240_SP5.exe' to bring it up to 7.6.2-sp5 so it can work with 2350's properly.
After all updates were in, it was at 7.6.2-sp5 - he used the sultan keygen with expiry date set at 2027 to put in a valid registration code for only basic. Right away it says it is expired when code went in. That is normal for it.
He ran expiryfix.exe program on it and ran it again and worked ok.
After he got to the main screen he went to options and security and then put in codes for pro and proplus, added fleet counts and unlock counts.
He then installed the drivers for adapter, then ran insite again, set up adapter, and connected to truck.
