So I just purchased this tractor not long ago.
I finally pulled the IMAP and cleaned it.
This is what it looked like at 295K miles.
How often should I clean it?
Thank you
Put in a new one and call it good.
(02-18-2020 )Unilevers Wrote: [ -> ]you should replace it
Yeahs I’m sure that's a good idea.
I took a toothbrush to it for now.
Now I have to find out where the rest of the sensors are located on this X15.
IMAP is the only one I'm familiar with.
Thank you
(02-18-2020 )Mattman Wrote: [ -> ]Put in a new one and call it good.
Yeah hopefully Peterbilt stocks them or I can locate a cummins dealer.
Thanks.
Would you know where I can look up the location of the other sensors that I should be replacing are located?
QuickServe. Register for free. It’ll tell you everything. And most all kw Freightliner and peterbuilt including Cummins should carry them without issues. I never had problem finding them.
(02-18-2020 )Soulreaver0102 Wrote: [ -> ]QuickServe. Register for free. It’ll tell you everything. And most all kw Freightliner and peterbuilt including Cummins should carry them without issues. I never had problem finding them.
Thank you! I appreciate the information.
I'm a first time OO trying to get as much information as possible.
Take care
(02-18-2020 )Edjahman Wrote: [ -> ] (02-18-2020 )Soulreaver0102 Wrote: [ -> ]QuickServe. Register for free. It’ll tell you everything. And most all kw Freightliner and peterbuilt including Cummins should carry them without issues. I never had problem finding them.
Take care
You're welcome. We’ve all been there. Read learn. Do as everyone recommends and you should be fine. Maintaining your equipment is very important
