Full Version: injectors
Looking at replacing all 6 injectors and came across flight diesel ones for 288 each. Anybody know anything about this company? Its a big savings but if they are junk your just wasting money.
I would say oem only but I got 2 bad ones from Cummins last March so dunno
These have a one year warranty so im thinking about trying them.
you did not mention what engine this was for.
At the very least, educate yourself on the subject so that you can make an informed decision, and look past some bulls$it advertisements,.. etc. ...
http://rawze.com/forums/showthread.php?t...67#pid4367
(02-28-2020 )Rawze Wrote: [ -> ]you did not mention what engine this was for.
Its a cm870, I was hoping someone else had tried them> cummins reman is 641.00 but if that's the only way to get one that will last then I wood rather fork out the extra money.
(02-28-2020 )tdawg Wrote: [ -> ]
a CM870/871 would be a toss of the dice. If they are cheap enough, you could handle any consequences they might cause yourself, .. and the truck was de-mandated,... and there was a guarantee on them for at least passing a leak test when I got them and installed them,.. Then I would consider it if it was a clean, reputable shop.
For a CM2250 or CM2350 -- no freggin way!.
Reference URL's
